Hi.
I created a main menu that is only used to select the desired language.
On the computer it works perfectly, but on the mobile version I can see the diferent options to choose. I mean, I can see the menu button but can't choose any option on it.
Could you help me?
Thank you.
please send me an url to your site.
solution: go to Adamant Options >> Layout >> Navigation Menu and change color settings for submenu - those settings are also applied to mobile menu.
Thank You Surgeon.
