Problems with Safari
edited January 2015 in Chillout Posts: 2
I purchased the chillout theme recently, but there are compatibility issues with safari (Version 7.0.6), is this a known issue, can this be resolved anyway? Screenshot attached.
First i thought it is only a problem with my Website, but your Demo have the same issues.
Thanks for your help.
    Hi, thanks for the report.
    Do you get any javascript errors?
  • Thanks for the quick reply, I have updated Safari and now everything works fine.
    good to here that!
    Do not hesitate to rate our theme ;)
