Air said: Switch to uncompressed to not make your work harder ;-) http://apollo13.eu/docs/hypershot/#!/advance_menu_use_compressed_js_amp_css
/******* Lightbox *********/ $e.lightbox();
/* * nyroModal v2.0.0 */
.bricks-album .brick .cov { display: none;}
Then I believe you will have to follow this answer http://support.apollo13.eu/discussion/763/how-do-you-remove-all-lightbox-like-effects-from-hypershots/p1
However you don't have to do this part With kind regards.
im in child theme
thanks
it is in appearence-editor??
Not all files are visible in wordpress editor. You should edit it via FTP.
i tried it and the lightbox is still on
http://new.boazpic.co.il/
thanks
It looks like your changes were not saved.
i remove it and i steel see the lightbox
thanks
Please add this custom CSS: Hope this time it will work like you want :-)
