There's a big issue with the mobile navigation (tested in chrome). Once you click on the mobile nav icon, the menu slides in from the left but doesn't slide back properly. It's not very fluid.
No, once the left menu is revealed, its not very responsive. - There's no close button to hide the menu - If you swipe to push the menu back, it doesn't respond every time - After multiple swipes, the menu slide back but the whole menu and logo disappear I think the mobile nav needs a lot of work honestly
Hello again, please take a look at our demo page of Chillout theme, the mobile menu behaviour should be better, I'm still working on it, but surely You can see changes.
Hey, wow - a lot better on the demo page! Working a lot better. When will the update be available? Really appreciate the fast response and communication. It's been a pleasant change compared to some other theme developers in the Evato community. Thanks
Hi, are you able to do some changes in files? If so: open menu_bar.php file and find line nr 16, which looks like this <a id="logo" href="<?php echo esc_url( home_url( '/' ) ); ?>" title="<?php echo esc_attr( get_bloginfo( 'name', 'display' ) ); ?>" rel="home"><?php and change it into this: <a id="logo" href="#page_very_top" title="<?php echo esc_attr( get_bloginfo( 'name', 'display' ) ); ?>" rel="home"><?php
Post edited by surgeon on
animation speed is the issue, right?
You can expect new version of Chillout theme will be ready tomorrow.
the problem is that now I see some flaws in menu behaviour...
Please be patient, perhaps tomorrow.
You can now download the latest update with this fix.
How can I make the center logo a Navigation anchor (home)?
<a id="logo" href="<?php echo esc_url( home_url( '/' ) ); ?>" title="<?php echo esc_attr( get_bloginfo( 'name', 'display' ) ); ?>" rel="home"><?phpand change it into this:
<a id="logo" href="#page_very_top" title="<?php echo esc_attr( get_bloginfo( 'name', 'display' ) ); ?>" rel="home"><?phpAll the Best.
