The filtering of album genres using the filter bar is working good, but it's display is making a strange output and covering my album's bricks. (www.nomadnocry.com)
Is there a way to customize this filter menu and:
- Put its background color menu to transparent
- Change its position in the album list page
- Diplay filter items in column instead of rows
- Make it appear in the header instead
Many thanks for your support,
I understand that you wish one of those, not all together:-) Then text in filters wont be visible To where? Filter is positioned with CSS so you can make it easy I believe. It is not good idea in wide screens and such layout. It is vertical when screen gets narrower. It would be hardest. BUT we could try to add some padding, so filter won't cover your images.
Try with such custom CSS first: With kind regards.
I added this custom CSS :
#albums-filter {
position: static;
But seems it doesn't affect the display. Same result.
The ideal would be that the filter bar is located on top of the albums bricks not on the albums.
Kind Regards,
OR you try stronger rule with such CSS instead: With regards.
Working with the stronger rule.
Thx :-)
