Hello Apollo13 team.. I have run into a couple of formatting bugs when I view my site on my iPhone 6. I have linked screen shots. Can these be fixed in a theme update? Loving Chillout so far.. Keep up the good work! --Austin
One more bug.. When I go to share my website on Facebook.. In the meta description on the post.. It shows "By: Apollo13" can this be turned off in the theme or updated so that it does not show?
Hello, thank You for the report - styling issues should be fixed and ready in one day or less. I'll let You know when it's ready.
As for facebook issue: there's a line of code that is responsibile for that, it's located in header.php file placed in theme folder. Find this, line nr 9: <meta name="author" content="Apollo13.eu" /> and change it according to your needs.
Did You get latest version? Did You updatet all the plugins? There are 'Visual Composer extend by Apollo13 for Chillout' and 'Custom post types for Chillout wp theme' plugins to update (to version 1.0.1).
I'll investigate this later, but for now You can do the manual update.
When You unpack the theme package You get the folder named 'chillout' - open it, go to location 'chillout\inc\plugins\' the plugin package is here. Take chillout-plugin.zip and vc_extend_apollo13_chillout.zip.
Hi, strange thing - I can see some differences between styles on your WordPress installation and this what I've developed. I'll double check everything and prepare another update package (with the same number).
Oh... Okay. Thanks for all the research. I tried removing and reuploading and I am still seeing the same formatting thing.. Everything else on the theme appears to be working though.
I do not see it on the demo.. Only when I upload the newest versions of the theme to my site... Because of this issue I have to use the 1.0.3 version of the theme.
Hello, sorry for it takes so long. First: there's new version ready for download - You could try use this one. Second: I need to have an opportunity to investigate your problem, so You must let me take a look at those errors on your WordPress installation. Unfortunately I can't reproduce the situation which You've described.
Design X Develop
https://designxdevelop.com
Design X Develop
<meta name="author" content="Apollo13.eu" />and change it according to your needs.
Design X Develop
Design X Develop
Design X Develop
As for installing plugins manually please refer to: http://codex.wordpress.org/Managing_Plugins
Design X Develop
Design X Develop
new version is available to download, the number (to 1.0.4) has changed due to some additional fixes and changes.
Design X Develop
Design X Develop
Design X Develop
Design X Develop
Design X Develop
