Hello, I went to upload a wider/larger logo shield to house my logo, but it still retains the original soze of the prvious logo. How can I make the logo shield larger to have a larger logo as the logo just bleeds over the edges. Thanks
Also, when viewing the site on a smaller device, like ipad/iphone, the headers and other areas of text etc begin to bunch up and look odd as though the kerning/line height is not correct. Is there an option to change this?
Hi, sorry for being not precise. I need You to show me what are You not happy with. So as for logo and the shield under the logo - please place logo image or shield image You want to have and I'll investigate the issue. As for your second report - please send me screenshots with marked areas that are displayed incorrectly.
Sorry, but the site is live for client and I cannot change this.
Please, upload a larger shape/image/logo AND chnage the shiled say for a wider and longer shape and see what happens. Im simply pointing out it doesnt work properly and I need to change it
The shield I made to create a larger 'logo' area house a bigger logo does not work. The shield i uploaded was 215px x 210px but as you can see, it just confines it the the parameters of the old shield. When a larger logo is made, it does not 'centre' but left allign from the previous logos boundry,
Can You send me an url to your site or screenshot?
Yes please see link http://tinyurl.com/p7lspgc
I have made the logo fit to the shield size, but if I put in a bigger shield it doesnt work and looks odd.
please download the latest version of Cillout theme from ThemeForest and update it on your WordPress installation.
go to Chillout Options >> Layout >> Typography and change 'Line Height' parameter for 'Second font family to use in headings'.
http://www.apollo13.eu/docs/chillout/#!/installation_update_update_theme
You can backup and restore Chillout Options in Chillout Options >> Import / Export.
