Before version 1.3 the user had to click on the "i" button to display the item info, now it displays be default (upon load). How can I revert back to the way it used to be (not showing info at lightbox startup)? Thanks!
Thanks for the QUICK fix! You are right about the "i" icon, but it's better if the user sees the full image and doesn't know how to turn on the info than if the image is half covered by the info and the user doesn't know how to get rid of the info.
showInfoByDefault: trueline ~480 and change it toshowInfoByDefault: false.With regards.
js/script.jsWith regards.
I’m coming from this thread. Thanks for your quick reply, Air.
For any strange reason: This solution didn’t change anything.
That certain passage of the script looks like this now:
$('a.alpha-scope[data-group]').jackBox("init", {baseName: G.jsurl+"/jackbox",
className: 'a.alpha-scope',
defaultShareImage: G.defimgurl,
showPageScrollbar: true,
deepLinking: false,
Any ideas?
---EDIT
Issue is connected with thing that I explained in your other topic.
