Hi, I am having trouble getting started with this theme. I am working on a mac and have uploaded the theme when it is in it's Zipped form and everything seems to be ok. Then when I go to view the site it comes up with this message "Apologies, but no results were found for the requested archive.
I can't seem to get the rest of the theme on to the computer. At least I think that is what is wrong.
Can you help me please.
It seems something went totally wrong, but no worries.
Have you followed one of ways to install theme that are mentioned here http://apollo13.eu/docs/spaceship/#!/installation_update ?
Please try them.
If nothing helps I will try to help you more invasively way.
Are you working online or offline(I mean is your WP is available in internet)?
guitartrav showed me image what is going on and now I get it
Try this answer http://support.apollo13.eu/discussion/comment/1133#Comment_1133
I will change default setting in theme so it won't confuse other users.
Thanks for info.
This was not well documented.
I'm sure answer from your topic(please decide where you write) is working.
Is there possibility that you send me temporary admin access to your WP via private message here on forum so I could check what is going on?
If you REALLY wish to see same thing as our demo page go through installing demo data process http://apollo13.eu/docs/spaceship/#!/demo_data_images_sizes_and_others but I don't advice it.
If you wish to get same 'menu'(it is albums list) you have to add Albums list page as explained here http://apollo13.eu/docs/spaceship/#!/adding_album and add some albums.
Hope that helps somehow.
I will try tomorrow to extend documentation to make it more user friendly(it is 0:20 in my place).
Is there possibility that you send me temporary admin access to your WP via private message here on forum so I could check what is going on? Just create account for me, and you can delete it after I will tell you.
You have to add some pages and then this menu will show. Follow http://apollo13.eu/docs/spaceship/#!/adding_frontpage mainly these:
2. Add new page named Frontpage and another named Blog. You can leave them empty.
