Hello again, I've looked into your issue more carefully, and found that You're not using our shortcode to display gallery. Second thing (and the crucial for You): the row containing your gallery should have 'Full width?' and 'Full width content?' parameters checked. That should do.
thank You for the report, it looks odd.
I'll investigate this issue, and we'll fix it in upcoming update. I'll let You know when it's ready.
That should do.
