I have another page like this
http://ahojtadygema.cz/quixdeko/vyroba2 and when I click on the menu item, it just loads the homepage on the top. I need to be able to get on the exact section I am clicking on in the menu, is it possible somehow?
Thank you
when I'm on and click 'Kontakt' - it loads a home page and scrolls to Kontakt section.
It works as it should. What browser You use?
I'll double check it on other browsers.
And the issue, that You've reported is fixed.
I'll double check it.
I've fixed that bug, and the new version with this fix is available to download from ThemeForest. Hope You'll be satisfied.
