In a page of my website I would like to use the grid gallery (brick theme) but I need to put some text (just a brief description) before the images...Is it possible?
Right now all the images appears just below the header and even if I write something, the text doesn't appear...
Let me know
Thanx
Elisa
There is not possibility for this. I can help you modify theme, so it maybe be displayed somehow, however I can promise it will act good always as this would require extended testing on various devices. So you decide:-)
Do you have any suggestion?
Hope it works
OK, so to get what you need, you will have to make following modification:
Go to file: hypershot\single-album.php ~30, find this code and change it to also add this custom CSS Should do it.
I will try it and let you know
