I upgraded (by deleting everything and installing the new theme and child theme) I tried installing the theme upgrade through my WP admin panel but there isn't an over-ride like the instructions say there should be.
After installing I went to the required plugin's and installed them all and then went to activate them and got a white screen. My site was nothing but a white screen and do was the dashboard. I started deleting them from the control panel one by one and the plugin causing the issue is the: "Visual Composer extend by Apollo13 for Chillout"
Now when I try to create my home page without this plugin installed I don't have the navigation module. So many things on my origonal home page aren't working. I'm certain this plugin in necessary but I can't install it. I've tried in a variety of ways and no matter whats active and what's not... When I install that plugin, my site is gone.
1. Which version of Chillout did You install
2. As I'm not able to reproduce this issue I need to take a look at it on your instalation - so please install plure WordPress, and send me login credentials (do it via private message).
I couldn't upgrade it like the doc suggested because there isn't an override option on the install screen as it suggested.
I'll be happy to create a login for you. What is a good email address? Then I'll PM it to you.
I've send You PM. The credencials are not working.
I can take a look at your instalation, but - like I wrote You - the login credentials that You've send are invalid, so I can't access admin panel.
