There is no easy way to change its height. This due to fact the this header part is on its own way responsive and collapsible. Also its height is dependable on what parts of header is activated there. It shouldn't be touched so it works good on every resolution.
Anyway if you are familiar with firebug, or similar tool you should follow this topic http://apollo13.eu/docs/spaceship/#getting_started_how_to_do_it_i_would_like_to_modificate_theme,_how_can_i_do_it
to go well with editing CSS.
