Firefox images not responsive
edited March 2015 in Chillout Posts: 63
Hello
on firefox (mac and pc) my images are not responsive.
www.grau-wild.de
    this is Visual Composer issue.
    To fix that go to Chillout Options >> Custom Style and put this definition:
    .wpb_single_image .vc_single_image-wrapper {
      display: block;
    Hello
    this works but on portfolio there is the same problem if i use visual composer
    first portfolio on my site, text and images are not centered
    500 x 575 - 207K
    What do you mean by 'not centered'?
    Horizontaly? Verticaly?
    Which element from the screenshot You send has bad layout?
    if you open the displayed portfolio
    1783 x 1307 - 2M
    OK, now I get it. You've built 'Tower of Power' Work item with visual composer.
    I'm sorry, but this is not supported at the moment.
    The problem is only in firefox, isn't there a similar fix like this one:
    display: block;
    Well... maybe, I'll try to find something especially for You. ;)
    Just please be patient.
