Is there a way to disable the rotating effect on the clients, not only the effect, i like to have only the picture and on hover nothing should happen.
Because on IE if it rotates the text isn't shown but the image is mirrored, and on all other browsers i don't need the text.
yes, there's a solution, few of them.
Do You want to disable this effect on work items too?
nothing? no icons, no texts, right?
Until now i only want to disable it on the clients but its not wrong to know how to disable it on works too.
lines 249-255 of script.js file of chillout-plugin have to removed.
the file's path is
../wp-content/plugins/chillout-plugin/script.js
those lines look like: just remove this piece of code
btw: is there a way to make the plugin updateable with these changes?
The hover effect of the portfolio is only modified on my site not removed completely so it's still "attractive"
But it would be nice to save this modification on updates.
The site is online at the moment if you need to check something.
I noticed in IE the "load more" button of the Portfolio has a problem with the rotating effect.
We're not going to implement another option that would allow to disable this effect.
Which version of IE?
IE version is in the picture
Will be the IE problem fixed in the next update right?
