wrong template in "greatest works"-section
edited March 2015 in Chillout Posts: 6
Hi there,
can you please take a look to this link: http://flowmotion.apps-1and1.net/work/b2run/
I want to change the template like the "people"-section.
Thank you,
Florian
    Hello Florian!
    You can achieve something similar by:
    1. edit work item and set 'Description content position' parameter to 'right' (in metaboxes, below the editor)
    2. disable 'Show featured image' parameter
    3. put some images in media collection.
  • Hi,
    thank you for your quick reply! I´ve tried out your tipps, but I´m not lucky with the results ;-) I want this appearance for our "Greatest Works"-Section (see screenshot).
    Thank you,
    Florian
    1422 x 1016 - 1M
