Discussions
Categories
Home
Blame
Customize Side Bar
webhosting124
March 2015
edited March 2015
in
Blame
1. How to add the image at text widget in between title and words? as red area of image.png
2. How to slideshow 1 image in easy instagram widget?
http://imtinyscribbles.com/
Air
March 2015
edited March 2015
Hello there.
1. Can't you just insert
<img />
tag in text of widget? It also depends what is function of that image, and will it be displayed in only one place, or more.
2. Is that some kind of plugin? If yes then you should ask about it in its forum.
March 2015
webhosting124
March 2015
edited March 2015
Thanks you for your time. You have solve my problem.
2. Yes, i will ask the forum. Thanks.
Post edited by webhosting124 on
March 2015
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
115
OneLander
325
PhotoProof
591
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
March 2015
webhosting124
March 2015
Air
Discussions
Categories
Sign In
<img />
tag in text of widget? It also depends what is function of that image, and will it be displayed in only one place, or more.2. Is that some kind of plugin? If yes then you should ask about it in its forum.
