Hi Guys,
My website is having some issues - when I click on a tile on the home page to go to that particular work section, there is a huge white gap before my first image. Problem is, it only does it the first time you click on that work item, if you were to go into it again it loads the images as it should do. I need it to show up correct the first time as I have been applying for jobs and my work needs to show correctly or I may be having my applications discounted because my site is lacking. It's going to be a rarity that someone will click on a work item once and then go into it again so that it shows up properly.
My web address is:
www.smhdzines.com
I have attached an image of what I am talking about.
Have just updated to the latest version of wordpress, and my beach theme is 1.6.4.
Please help me asap.
Cheers
Sarah
I have checked your site on firefox and chrome and couldn't recreate issue. Can you give any more details, like browser, resolution, other useful things?
Also if it such critical, then instead of scroller, switch to slider in your works for time being.
It's on Chrome browser. I have a 27" screen so my resolution is set to: 1920 x 1080 resolution (recommended for my screen - as per control panel).
I did try to use the slider, but it just doesn't work properly with the display of my work, so I would much prefer to work out the issue with the scroller.
Basically when I go onto my website (and also a friend - tested to make sure not just my computer) and click on an item, there is that gap at the beginning - like there should be another image there but there is not. But if I go back to the home page, and then re-enter that particular piece of collateral, it shows just fine. It's almost like something to do with the actual loading of the scroller and once it has a memory of this it works fine.
My only concern is a potential employer may not look at it twice. I have tried all the other options for the showcase, and none of them are a way in which I want to display my portfolio.
I've also tried it on Firefox - however didn't have quite the same amount of instances it occurred. But it did happen. Screenshot attached.
Hopefully this helps?
Sarah
Any help would be greatly appreciated.
Cheers
Sarah
About line - couldn't see any, but It sounds like rendering issues that Chrome sometimes show.
As I said before I can't recreate this issue on my installation so I will need access to one, where it is occurring. So lets start with link to page where I can see issue, please.
Hope I can verify this with you:-)
