I'm wodering, if there is a possibility to organize the work navigation depending on the category. So the work navigation would just link within workpages of the same category.
I have tested and it works. But what is more I have added this in newest theme version so now you have switch for this in Works-> Single work settings -> Navigate by categories
If every user would swear that he/she wont use more then category for each work then it could be possible :-)
But lets try it:-) Go to fame\advance\utilities\post__work__gallery__blog.php line ~647 and change this to With kind regards.
I tried it, but unfortunately it didn't work. Tought there is no workpage with more than one category.
