Hi guys, just updated my Fame to 1.62 and unfortunately I heaving a problems, please check me site:
http://rajcheldesign.com/ problem appear on the home page and also I can't log in to the back end, the only way I can log in to the back end is through previous version of the template. Please advice.
It looks like you have some older PHP version. I will try today to change this new code to work with older PHP, and release update.
I am not quite sure if I can get fix this error, as I am not sure what exactly is wrong in code.
Could you please send me temporary access to your FTP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach LINK(!!!) to topic it applies to.
Hi there:-)
I have found out that you didn't update Visual composer plugin while making update, and this is source of issues. Please check change log, http://www.apollo13.eu/themes_update/fame/index.html mainly about version 1.6.0
Check here to see how to update plugins that are bundled with theme http://apollo13.eu/docs/fame/#!/installation_update_update_theme
