I am hoping that you might be able to tell me how to customize the colors of the buttons that are found in the Button 2 Plug in. I tried adding the code that was listed here:
http://support.apollo13.eu/discussion/2657 but no changes were visible even after clearing caches, etc.
By "Button 2 Plug in" you mean element form visual composer? If yes then this button has its colors set when you add it to page. Does it work for you?
I am able to make changes to the colors within the window that you've shown. I was simply hoping that there might be a way to further customize those colors. Any ideas?
Use such code as base for changing colors of orange button With kind regards.
That worked perfectly. Any chance you could give me a code for the hover as well? I'll see what I can do about generating it, but if you find it more quickly, great!
Thanks again,
Same code with
:hover
at end will do the trick With kind regards.
