When you click on a single porfolio works the navigation always points back to the main portfolio category which is my case is "Sold". I have another category which is "For Sale", and when you go into a single work from this category the navigation on the top still says "Back to Sold". Even though the item is not associated with this category. Is there a way that I can change this. So when you go into a single work from the "For Sale" category the navigation on top will say "Back to For Sale" and link to the main for sale page?
In version 1.6.1 we have added option "Navigate by categories" - If enabled then navigation in single work will lead to next/previous work in same category.
You will have to activate it is works settings.
This should help.
Thanks for data. Now I noticed that you made your "protfolio" as page named "Sold". That is why every work, returns to sold.
When I did category navigation in latest updates, I didn't do anything about this back button. I will take a look, and think of how I can solve this issue.
Will inform when it is done.
For now unpack file from attached ZIP archive, and upload this file to fame\advance\utilities
It will do the trick.
