Default Works Category, Remove 'All Categories'
edited April 2015 in Chillout Posts: 3
How can I remove 'All Categories' from the Works filter, and default list to a specific category?
Thank you
    I'm not sure if I understood You correctly:
    You want to have filter?
    But without 'All Categories' item, right?
    And You want to point one category among others to be selected by default, right?
  • Yes, that's exactly what I need.
    patobarbieri said: How can I remove 'All Categories' from the Works filter
    this requires custom work, need to edit some files.
    patobarbieri said: and default list to a specific category?
    it's impossible now. You can always narrow the work's list by use of 'Categories' parameter in 'Works List' shortcode edit panel.
