Delay Update Logo
edited May 2015 in Chillout Posts: 31
Hi!
I'm noticing a delay to edit the site logo. It takes on average 24h to update.
Can you help?
    Perhaps You should use ctrl+F5 key combination, or clear browser cache.
    It might be something with your host.
    To be sure I would have to try on your WordPress installation. I've never faced this problem.
