Hello! I cannot set the default theme. In a previuos thread you wrote “You need to switch beetween predefined skins – http://goo.gl/IbHAxZ" I chose ‘Default’ and click on ‘Import settings’ but it didn’t change anything…
If you have some caching plugin then this might be source of issue. Also we recently discovered that with new wordpress 4.2 importing functions not always work cause of change of coding in database. We will fix that soon :-)
If you will still face problems, then I will try to do it for you.
