Unfortunately this theme doesn't have such functionality. I believe that both your questions about video player aim to achieve something like video background, while this theme wasn't designed for this. However if you would add two videos and set album as background album, you will achieve some what effect that you look for:-)
Thankies for getting back to meh. OK. Kools. DUH!!!!! Why didn't I think of that. While on this subject how can I remove the left and right arrows on the homepage for both video slidershow?
Could you mark on screen shot which exactly arrows you mean? Cause there are few different :-) You probably mean main arrows and this CSS should hide them:
That code didn't work. It's the static homepage with video for example 2/2 videos it has 2 arrows says: 1/2 on both left and right. I have attached a photo....
Many Thanks,
The Team Of JM
.prev-parent, .next-parent{With kind regards.display: none;
Many Thanks,
The Team Of JM
