Sorry, this is Wordpress decision, and I believe that they know where title should be put in head area.
However what you say makes sense for me, but I don't think you will lose any noticeable position point cause of that :-) . However if that is the case, then I believe there should be plugins that move title "up". From template I don't have any power to move it.
Thanks for reporting this one!
We will fix it in next update, but meanwhile go to photon/header.php and remove this code from line 17 With kind regards.
For the search engines is better than the meta title is the beginning of source code.
Is possible to eliminate the second meta title and not the first?
Regards,
Andrea
head
area.However what you say makes sense for me, but I don't think you will lose any noticeable position point cause of that :-) . However if that is the case, then I believe there should be plugins that move title "up". From template I don't have any power to move it.
Ok.. thanks.. I'm sorry but I usually use joomla.. I'm new to wordpress..
Regards,
Andrea
