Hello, each time I put the text blocks or lines to the image on the slider such as on
http://www.danceatwork.nl/, they move away slightly. They are not sticking to the right spot. I used the image size as in the original images that came with the slider. Please advise. Many thanks, Horst
Maybe it will help you: https://nimbus.everhelper.me/client/notes/share/234533/Aa9wzzHMIBH8U0tttpGh7Li0oiHxIWW7/
You should always center or align your text.
I cant help you with this because i dont see your settings
Send me a screenshot.
Best Regards
Plus I cannot prolounge a whiteline_long, how do I do that? Thanks! Horst
This is more question to this plugin author then to us, as we only bundle it with theme, not create it :-) You can look here in their faq http://www.themepunch.com/support-center/
