I'm not able to change the height of the portfolio items. I've changed it in the admin page, and it's not responding on the front end. I changed it with css, but the space between the boxes remains the same height, leaving a large blank space. See
http://martechsvcs.com/ under 'brands we supply"
things that are to set in admin panel concern media sizes of open Work Item.
To manipulate the size of Work Item within a grid You can edit Work Item and change the size of it in metaboxes.
By looking at the custom style that You've made I assume that You want to make Work Items smaller.
if so - please paste those definitions in Custom Style section: and remember to remove previous definition, which is:
