well, I have a strange issue: I didn’t change anything except for the content of some posts. So I actually don’t feel guilty. Some of the separators in my main navigation suddenly disappeared. See the attached file.
All you report is connected with CSS and JS compression we try to solve in your other topics. And you did change - disable autoptimize plugin :-) Lets solve your other topic before you report any other such things :-)
The issue mentioned above happened again. I didn’t install any new plugin. All I did since it suddenly happened, was creating new content (pages). Any idea what might be wrong? FIY: Autoptimize is not in use anymore. I use Cloudflare as CDN and W3Total Cache for caching. I didn’t make any changes in the settings.
I believe I have solved this for you in past and it was connected to your menu, as I can see in HTML that structure is broken.
I will investigate now what it could be.
Withkind regards.
