StepfaneG said: onjourcomment activer la discution sur les albums ?merci par avance
StepfaneG said: Bonjourcomment activer la discution sur les albums ?merci par avance
$supports = array( 'title','thumbnail','editor' ); if(isset($apollo13)) { if ( $a13_apollo13->get_option( 'album', 'comments' ) == 'on' ) { array_push( $supports, 'comments' ); } }
$supports = array( 'title','thumbnail','editor', 'comments' );
<div class="real-content"> <?php the_content(); ?> <div class="clear"></div>
<?php comments_template( '', true ); ?>
English please!
If you ask about comments in album, then there is no option(and no place) for it.
Thank you in advance
as I said above, there is no option for enabling comments(discussion) in albums. You will have to modify few theme files if you wish to get it.
can you put me on the track?
tank you
Album post type don't have enabled comments, and so it doesn't have callas for comments, or even space where they should be displayed.
You will need to modify plugin a13_photon_cpt.
wp-content/plugins/a13_photon_cpt/a13_photon_cpt.php line 39 change this to Next go photon-a13/single-album.php line ~61 and after this code add this
This should get you started.
