Problem with mobile version
Hello guys,
I´ve been having trouble visualizing the web on a cell phone (i-phone) I am attaching you some images.
1) The main text just at the beginning gets cut in the edges
2) Two columns are weird
3) The call to action boton goes out of the box
4) The subtext in almost every section gets overlaped.
    guanabana said: 1) The main text just at the beginning gets cut in the edges
    You mean text in revolution slider, right?
    guanabana said: 2) Two columns are weird
    Columns are just supposed collaps, but You can design another set of columns just for small devices. Edit any column and check 'Width & Responsivness'.
    guanabana said: 3) The call to action boton goes out of the box
    Didn't notice that, please attach specific screenshot.
    guanabana said: 4) The subtext in almost every section gets overlaped.
    It's caused by 'Josefin Slab' font You're using. It's not en error, just increase 'line-height' for this font in Chillout Options >> Layout >> Typography.
  • Thanks for your response, 1) Yes, i ment the text in the slider 2) I will change that 3) I am attaching the image so you can see the call to action boton at the bottom (the green one) 4) I will change this then..... Thank you again
    540 x 960 - 51K
