Thank you very much for the theme that is really great.
I juste wonder, as I have no use of it as it is overlaying the photos in album mode, is it possible to remove the footer "bar", that can go up and down by clicking on the center object ?
Thank you very much
AP
I think fastest and safest way will be to hide it with custom CSS like this:
#footer{With kind regards.display: none !important;
Kind regards,
AP
That would be grat. Thank you.
1. I don't know what you mean, could you explain more?
2. You should start new topic for question about different case. Thanks.
Ok I will start a new topic.
Thank you
