So, i hope i explain my Problem as easy as possible:
If i go though the upper left Menu to my Homepage i can not work on my different sites, they simply doesn't load.
I just see the Photon Circle moving around.
But if i go first to all my Themes, and then select to work on my homepage settings i can load all the sites of my homepage. The problem is just that i cannot really edit them with this option..
Thank u for ur support and excuse my bad english. I can send u some screenshots if u want!
Live link please, maybe there is some JavaScript issue/conflict.
