Layout problems
Dear Support,
I have faced with layout problems (attached in file) with scrolling - up and down - it doesnt go untill the end of scrolling. (tested on Firefox and Safari).
The same problem is in "category" posts list.
Thank you!
    Can You please provide me an url to your website?
  • Dear surgeon,
    I have sent you a private message with url to my website.
    please be more specific, I looked onto your website, and it seams to work fine.
    What schould I do (step by step) to reproduce the issue You're facing.
  • edited September 2015 Posts: 10
    Hello!
    If I go to the main page to "Journal" and then "read more" - everything fine.
    But if I press after that on the date (on photo) - opens the page of post. And this page has problems with layout like on the screenshots. Also, if I press category, for example "Moiuntains" - opens list of news with such category. This page has also the same problem with scrolling like on the screenshot.
    Hope it will help you to find out :)
    Post edited by lynkprojects on
    Ok, but it's not a bug.
    These white margins are a part of desing.
    You can change it. Go to CeeVee options >> Custom styles and paste this definition
    .pure_page_wrapper {
    padding: 20px 30px;
    change the first value to something else.
  • I am sorry for misunderstanding.
    Attached one more file.
    Link: http://mansprojekts.lv/zujs/category/mountains/
    I can not scroll down until the end.
    1365 x 747 - 476K
    Ok, now I got, I'll take a look at it.
  • Dear Support, have you found the problem?
    by the end of the week the update schould be ready.
    Meanwhile You can try this definition.
    :not(.a13_testimonial_cloud_interior) .owl_row_wrap.pure_page_wrapper {
    min-height: 460px !important;
    Inform me please if it fixes this bug for You.
  • Thank you,
    But unfortunately it didn't help.
    I will wait the update! :)
    Hello again!
    Could You please provide me an access to your website as it is in maintanance mode now?
    The issue You've reporte is perfectly recognized, and it should be fixed by css code I gave You, I'd like to check it with your installation.
