Transparent Line Below Menu and Above Footer
in Fame Posts: 33
Hey I think it may be me just having a long day- but I cannot figure out how to get rid of the transparent line that shows below the top menu and above to lower footer.
First photo shows transparent line
Second photo is from the Fame Preview Examples "Minimalistic" - that does not have the line
    edited September 2015 Posts: 10,970
    Hello there:-)
    Maybe try deactivating menu top border:
    If that is not it, then please post live link or bigger screen shot with marked lines you wish to remove.
    1020 x 470 - 38K
    Hey so here is a larger photo- pin pointed which lines I am talking about. The transparent line below is what I am trying to get rid of, similar to the Fame "Minimalist" look (attached photo again). Menu Top Border gets rid of the line between the logo and menu (but I want to keep that). Thanks for your help!
    737 x 408 - 133K
    1028 x 235 - 46K
    Ooo you mean shadow :-)
    Use this custom CSS:
    #header {
    box-shadow: none;
    ahh beautiful, thank you!
    584 x 317 - 57K
