Hi
I've noticed that the image thumbnails in the "Recent Posts" widget in the sidebar is scaling really badly. I just looked at your demo on themeforest and it does the same there but on recent comments they look just fine. Is this something you can help out width?
Thanks in advance.
We'll fix this issue in upcoming update, but for now:
please go to Adamant Options >> Custom Styles and paste this definition this should help.
Sounds good with the update.
Unfortunately the css you sent did not do the trick
This will be fixed in upcoming update, just as I said previously, but if You want to have immediate fix then You have to send me the login credentials for admin panel. Please do it ONLY via private message.
