Adding new item in the Navigation slider
I have aded a new item in the main menu. I call it "Test Anchor". As you can see from the screenshot attached, the new item is displayed in the top navigation, but not in the Navigaton slider. I've also add new row via Visual Composer, right after the Contact anchor.
Do you know how can I solve this problem? Thanks!
    1. Perhaps there is sixth item, but it's not visible. Did You try to drag slider?
    2. You can change the number of visible items; edit Home Page, go to the very bottom and change 'Maximal number of navigation labels' parameter to '6'
    3. If none of above, then You probably didn't configure new row correctly. Refer to http://www.apollo13.eu/docs/xpert/#!/configure_page
