How to add Revolution Slider to Front Page
How can I add the Revolution Slider when I select Post as my front page display?
In the title bar only can select image to display on "rev slider-3.jpg".
    Hello there:--)
    You have to switch title bar off. Next you have to add revolution slider with Visual composer :-) It has special element for it. Try it, you should be able to do it :-)
    Hello there:--)
  • Air, thanks for your helps.
