demo data import failed
I want to import the chillout demo data, but it failed. See picture attached. What can I do?
Best regards,
Florian
    Are You sure that You're uploading the right file?
    Or - as the notice says - please contact your hosting provider.
    Check you log files, what do they say (might have to ask host if you don't have access to the logs).
    Could be necessary to up your memory allocated to PHP.
