Description.
When using the theme, there are two site titles and taglines displayed.
List of ACTIVE plugins.
The only active plugins were the ones installed by the theme.
Wordpress version.
Version 4.3.1
Theme version you are using.
XpertVersion: 1.0.1
Have you made any code modifications(CSS, JS, PHP)? If yes write what you changed.
I have not made any modifications to the code.
Thank You for this report. We'll prepare update that fixes this issue.
The quickfix for now:
edit file: ..\wp-content\themes\ceevee\functions.php
find line
add_filter( 'wp_title', 'a13_wp_title', 10, 2 );
(line 365) and remove it.All the Best.
