Masonry Grid Strange behavior
in Xpert Posts: 2
List of ACTIVE plugins.
Ones installed by the theme.
Wordpress version.
Version: 4.3.1
Theme version you are using.
Version: 1.0.4 of Xpert
Have you made any code modifications(CSS, JS, PHP)? If yes write what you changed.
No.
Any additional information that might help.
After installing the theme and demo data ( default) , I made some small adjustments to customize the theme.
Therefore, the post masonry grid (blog page and work page ) fail to be displayed ( checked on multiple browsers and computers) . Finally, I found that if I use wordpress preview page , post masonry grid are visible (?).
In addition , I note that the pie chart does not take into account the number ( 0-100 ) indicated in the settings. It appears without metrics.
PS. If i move the masonry grid on the firt row, it works ! Very Strange.
    please provide an url to your website.
  • hello,
    url : testing.myssii.fr
    It would be better for me to taka a look at your work from inside, so could You please send me login credentials to admin panel? Do it ONLY via private message.
