Reduce gap between search box and footer text on main navigation?
Hi!
Is there a chance to make the gap between the search box and the footer text smaller? There’s a pretty big empty gap between these two things.
    Hello there:-)
    Could you send link to you site so I could see what is causing this in your case?
    Of course: http://www.dennisknickel.com
    For this please use this custom CSS:
    #header #footer{
    padding-top: 20px;
    Hm, that doesn’t change it…
    I added it in Appearance > Custom CSS
    Is there anything missing?:
    #header #footer{
    padding-top: 20px;
    I don't see this in your custom CSS. Please make sure it is there, and that you have refreshed your chache plugins (if you have any).
    I’m sorry… I always forget to purge the cache. ^^
    Thanks! It works. :)
