Having a problem where after using the site for a short period on a mobile device, the mobile (hamburger) menu stops working. You click it and nothing happens.
I was able to duplicate this in your demo:
http://photon.apollo13.kinsta.com(either on my phone or by just shrinking my desktop browser to roughly phone size in width & height)
On the main page, I click the mobile (hamburger) menu & it works fine.
I select Albums
Sometimes as soon as Albums loads the mobile menu no longer works
Other times, I need to scroll to the bottom of the page and then back to the top & it stops working
Any ideas?
First again would be to switch off AJAX, as there is probably something that throws off detection. As soon as I will detect what again mess script I will reply and send fix.
Thanks again for reporting this. AJAX on whole page is root of all evil
Thanks again for this report!
