I´m using a Theme Child, and i would like to know if i have to create USER folder on child theme, so then wordpress will create a user.css file there ?
Because, all of my changes in ChillOut menu, does not make any changes in my site.
rtsolucoes said: I´m using a Theme Child, and i would like to know if i have to create USER folder on child theme, so then wordpress will create a user.css file there ?
No. The user.css file is loaded as a last style file.
rtsolucoes said: Because, all of my changes in ChillOut menu, does not make any changes in my site.
What changes, can You give a specific example?
But some of options are changed by You, right? Can You change some of the options right now? I would like to take a look at your installation, please send me via private message login credentials to adnim panel.
You can see on attached image, that i changed settings "Menu padding" and "Font size for menu items".
But when you see to my website, the CSS values does not has these values.
Settings Menu Values
Menu padding - 6 and 6
Font size for menu items - 14px
My website CSS Values
Menu padding - 3 and 0 (the default values)
Font size for menu items - 10px
