Doesn't show content from blog&portfolio
link http://boliuk.com/#a13_Blog
I've installed your theme and start to make changing content. The problem is that content doesn't show in this 2 topics (but it exists after exporting http://boliuk.com/blog/ )
Could you explain what the problem and how I can fix it. Thanks.
    can I look at your installation? Could You please send me login credentials to admin panel? Do it only via private message.
    thank You for this report.
    The problem is that after demo data import You'd have to have three Grid Elements imported, and this is what You're missing right now. Xpert at this moment require those Grid Elements in order to work properly.
    In attachment file there are exported Grid Elements - just import this using WordPress Importer plugin.
    After that - edit 'Post Masonry Grid' shortcode that display Works and Posts, go to 'Item Design' tab and select 'Xpert post layout' for posts and 'Xpert Work layout' for works.
    Using another grid element layout will be fixed in upcoming Xpert update.
    zip
    zip
    xpert.wordpress.grid_elements.xml.zip
    2K
  • Hi,
    Thanks. Now all working well.
