Mobile Responsive Problem
Hi… Here are my website developed using this theme… http://uprising.com.my/ But what happen to mobile responsive? everything had been disabled… What should i do to fix it?
Here are the screenshot for mobile view :
    two things:
    1. your server is rather slow, and by result I get 14 Gateway Timeout errors, that could cause incomplete page load and in consequence incorrect working. It's happening only in mobile mode.
    2. You're using Chillout in 1.2.8 version, we highly recomend to update it. The latest version is available to download from ThemeForest
    also You should try to deactivate all extra plugins of your choise and then run test.
  • HI... I've already doing both action... however, there's show error as displayed in image attached...
    I dont know how to solve this... help me please... >.<
    929 x 1600 - 96K
    Again - there's a lot of server timeout messages. Don't expect the page to work properly if server is suffering performance issues.
