I have noticed there are options to edit the logo top and bottom padding. This is a great idea and I was wondering if there is a simlar setting for the menu items. I would like to edit the padding top and bottom for the main menu items which would result in the menu button being higher. This may already exist, but I cant find it. Please help. Thanks.
Nope, there is no setting for this in panel but you can easily achieve it with custom CSS: With kind regards.
Thanks for that custom css code. It worked very well.
I am having another small problem as a result though. The arrows (to indicate a sub menu) are now not not centered vertically / in line with the text. Is it possible to achieve this?
Also, I am loving the theme. Very nice looking design and very unique.
I appreciate your help and thanks again in advance.
Use this custom CSS also: I am glad theme is working fine for you:-)
