hi,
i'm building a one page design site and i have a problem on my navigation menu.
I already read all the documentation and i didn't find an answer, i followed all the instuction in your documentation for building the menu with the navigations anchor and it's built successfuly the navigation bar but when i click on one of the links (contact for example) nothing happen, no scrolling effect. I just have "#contact" added at the end of the url.
If someone have an answer that will be great
Think you for your time
Here is the url of my website www.evocitycar.com
you can use for example the link "contact" in the menu bar (last link on the right)
I tried to find a solution but i didn't found anything and like you said it's must be a javascript error
Thank's for your answer
we are aware of an error, and exactly tomorrow we'll send fixed package to ThemeForest team, so please stay tuned.
Unfortunetaly You'll have to wait until Monday/Tuesday. The update is not ready yet.
I'll wait until the update release
Thank's again for the information
The new version of Adamant theme is available to download from ThemeForest.
I just update my theme but nothing change, i checked the version and it's the new one
Do you have a solution because the probleme still the same
Thank you
You need to update 'Visual Composer extend by Apollo13' plugin to version 1.3.9
how can i do that ? I'm on the 1.3.8 version of 'Visual Composer extend by Apollo13' but when i try to update it, worpress tell my that i already have the latest version
1. Navigate to '..\wp-content\themes\adamant\inc\plugins'
2. copy 'vc_extend_apollo13.zip' file to '..\wp-content\plugins' and extract it there (it'll overwrite existing 'vc_extend_apollo13' folder)
that's it!
Thank you very much
